跳转到主内容
Fujifilm Endeavor 100ix Battery Door Replacement
你所需要的
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 2 中的图像 1,1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 3 中的图像 1,1
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 5 中的图像 1,1
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 6 中的图像 1,1
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 7 中的图像 1,2 Fujifilm Endeavor 100ix Battery Door Replacement: 步骤 7 中的图像 2,2
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
结论
Eric Nicolai
于01/10/11注册
679 声望
创作了6篇指南
团队
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G5
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,861
