跳转到主内容
Fujifilm FinePix Z90 Lens cover/case Replacement
你所需要的
  1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: 步骤 1 中的图像 1,2 Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: 步骤 1 中的图像 2,2
    • Use a small #000 Phillips screwdriver to take the screws out. Keep all the screws in a container and the two different types separate.
    • Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
  2. Fujifilm  FinePix Z90 Lens cover/case Replacement: 步骤 2 中的图像 1,2 Fujifilm  FinePix Z90 Lens cover/case Replacement: 步骤 2 中的图像 2,2
    • Take the two screws on the left side and the two screws on the bottom of the camera.
  3. Fujifilm  FinePix Z90 Lens cover/case Replacement: 步骤 3 中的图像 1,2 Fujifilm  FinePix Z90 Lens cover/case Replacement: 步骤 3 中的图像 2,2
    • By now you will have the front case and the back case separated from each other.
结论
Sam Clark
于11/03/15注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 UMass Dartmouth, Team 1-6, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G6
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 250
