跳转到主内容
FujiFilm FinePix S4500 LCD Replacement
你所需要的
  1. FujiFilm FinePix S4500 LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 LCD Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 LCD Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 LCD Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 LCD Replacement: 步骤 6 中的图像 1,2 FujiFilm FinePix S4500 LCD Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 LCD Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 LCD Replacement: 步骤 8 中的图像 1,2 FujiFilm FinePix S4500 LCD Replacement: 步骤 8 中的图像 2,2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
结论
另外一个人完成了本指南。
Vicente Rios
于01/25/17注册
708 声望
创作了6篇指南
团队
Cal Poly, Team 9-4, Banghart Winter 2017 Cal Poly, Team 9-4, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 573
