跳转到主内容
FujiFilm FinePix A340 LCD Screen Replacement
你所需要的
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: 步骤 1 中的图像 1,1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 2 中的图像 1,3 FujiFilm FinePix A340 LCD Screen Replacement: 步骤 2 中的图像 2,3 FujiFilm FinePix A340 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 3 中的图像 1,2 FujiFilm FinePix A340 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Now that everything has been disconnected from the board, remove LCD screen.
结论
Cody
于04/18/10注册
47 声望
创作了4篇指南
团队
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G11
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 6,245
