跳转到主内容
简介
This guide will show you how to remove and replace the speakers.
  1. Use a #3 Hex screwdriver to unscrew all four 3mm screws."
    • Use a #3 Hex screwdriver to unscrew all four 3mm screws."
  2. Gently remove the outer shell. It should be relatively easy to pull apart. Don't be afraid to apply a necessary force.
    • Gently remove the outer shell.
    • It should be relatively easy to pull apart. Don't be afraid to apply a necessary force.
  3. Pull out the device from the external case. Unscrew all 12mm T Head screws using a T10 screwdriver.
    • Pull out the device from the external case.
    • Unscrew all 12mm T Head screws using a T10 screwdriver.
    • Unscrew all 6mm T Head screws using a T10 screwdriver.
  4. Gently remove the side plates by using your hands to pull off. Use plastic opening tool to pry off the back plate. Work on the side with the Fugoo trademark.
    • Gently remove the side plates by using your hands to pull off.
    • Use plastic opening tool to pry off the back plate.
    • Work on the side with the Fugoo trademark.
  5. Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the speaker cables.
  6. Carefully untangle the wires that are connected from the speaker to the motherboard. Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
    • Carefully untangle the wires that are connected from the speaker to the motherboard.
    • Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
  7. Use a #3 Hex screwdriver to unscrew all six 3mm screws." While holding the case with one hand, pull up on the speaker you wish to replace. While holding the case with one hand, pull up on the speaker you wish to replace.
    • Use a #3 Hex screwdriver to unscrew all six 3mm screws."
    • While holding the case with one hand, pull up on the speaker you wish to replace.
结论
Abdul
于2017年02月17日注册
503 信誉积分
创作了4篇指南
团队
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 791
