跳转到主内容
简介
Use this guide to remove and replace the motherboard.
  1. Use a #3 Hex screwdriver to unscrew all four 3mm screws."
    • Use a #3 Hex screwdriver to unscrew all four 3mm screws."
  2. Gently remove the outer shell. It should be relatively easy to pull apart. Don't be afraid to apply a necessary force.
    • Gently remove the outer shell.
    • It should be relatively easy to pull apart. Don't be afraid to apply a necessary force.
  3. Pull out the device from the external case. Unscrew all 12mm T Head screws using a T10 screwdriver.
    • Pull out the device from the external case.
    • Unscrew all 12mm T Head screws using a T10 screwdriver.
    • Unscrew all 6mm T Head screws using a T10 screwdriver.
  4. Gently remove the side plates by using your hands to pull off. Use plastic opening tool to pry off the back plate. Work on the side with the Fugoo trademark.
    • Gently remove the side plates by using your hands to pull off.
    • Use plastic opening tool to pry off the back plate.
    • Work on the side with the Fugoo trademark.
  5. Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the speaker cables.
  6. Carefully untangle the wires that are connected from the speaker to the motherboard. Carefully untangle the wires that are connected from the speaker to the motherboard.
    • Carefully untangle the wires that are connected from the speaker to the motherboard.
  7. Use tweezers to remove two ribbon wires on left and right side of motherboard. Do not pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard using an iFixit opening tool.
    • Use tweezers to remove two ribbon wires on left and right side of motherboard.
    • Do not pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard using an iFixit opening tool.
  8. Pull out the motherboard halfway. Unplug the ribbon gently using a tweezer.
    • Pull out the motherboard halfway.
    • Unplug the ribbon gently using a tweezer.
    • There is a hidden ribbon on the motherboard, which becomes visible when the motherboard is been pulled out.
  9. Remove the motherboard and battery from the device. Use a #3 Hex screwdriver to unscrew all four 3mm screws."
    • Remove the motherboard and battery from the device.
结论
Abdul
于2017年02月17日注册
503 信誉积分
创作了4篇指南
团队
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G1
4 名成员
创作了5篇指南
5条评论
I would like to know where you purchased a fugoo tough or fugoo tough xl motherboard. Thanks you!!
Rhett Mccrady - 回复
Hi, I just opened my e-mail and this half information Ifixit was there. Wow, I spent weeks researching to find a motherboard. I called Fugoo and they assisted me with the major difficult project. ITs so simple to disassemble. You unscrew it and open it up. Very well built and engineered Bluetooth Speaker. MORE INFO NEXT COMMENT
Rhett Mccrady - 回复
change the battery just buy a similar battery and swap out the plugs. Very simple too. All I wanted was original though. The Fugoo speaker is awesome and the best. There customer support is perfect. Although, my only problem was with half information given and the details left out. For example, HOW TO REPLACE BATTERY.. The %#*@ instructions are the same as yours. Its how to take it apart. SO SIMPLE. Did you forget to tell everyone how to get the battery or how to modify one, because you can only get them in china and good luck its impossible. MORE INFO NEXT COMMENT
Rhett Mccrady - 回复
Amazon has them and the Harmon Kardon is a good replacement ($12)you have to swap plugs is all. And you mister your video is not how to replace a motherboard. Its how to take it apart. then the end. Where in the fxxk you find one is my question, because you did not even show a picture of the new one and where to get it or a picture of it installed.
Rhett Mccrady - 回复
How Funny all the Fugoo stuff are identical. I wonder who stole from who. Open-source !&&* you do not even have to take one apart to take pictures. LMFAO
Rhett Mccrady - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 23
总计 789
