当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
Gently pull up and off the outer casing.
Do not feel afraid to use a bit of force if necessary.
Remove the internal device from the outer casing.
Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
Use your hands to gently remove the side plates.
Use an opening tool to pry off the back plate with the Fugoo trademark.
Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
Separate the two slowly and consistently to avoid damaging the speaker cables.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与8其他贡献者
于02/17/17注册
527 声望
创作了4篇指南
徽章: 8
+ 5更多徽章
USFT-HOFFMAN-S17S19G1
4 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 936
