跳转到主内容
Fugoo Tough XL Case Replacement
你所需要的
  1. Fugoo Tough XL Case Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Case Replacement: 步骤 2 中的图像 1,2 Fugoo Tough XL Case Replacement: 步骤 2 中的图像 2,2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Case Replacement: 步骤 3 中的图像 1,2 Fugoo Tough XL Case Replacement: 步骤 3 中的图像 2,2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Case Replacement: 步骤 4 中的图像 1,3 Fugoo Tough XL Case Replacement: 步骤 4 中的图像 2,3 Fugoo Tough XL Case Replacement: 步骤 4 中的图像 3,3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Case Replacement: 步骤 5 中的图像 1,1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
结论
另外一个人完成了本指南。
Abdul
于02/17/17注册
527 声望
创作了4篇指南
团队
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 933
