跳转到主内容
Fugoo Tough XL Bass Speaker Replacement
你所需要的
  1. Fugoo Tough XL Bass Speaker Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Bass Speaker Replacement: 步骤 2 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 2 中的图像 2,2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Bass Speaker Replacement: 步骤 3 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Bass Speaker Replacement: 步骤 4 中的图像 1,3 Fugoo Tough XL Bass Speaker Replacement: 步骤 4 中的图像 2,3 Fugoo Tough XL Bass Speaker Replacement: 步骤 4 中的图像 3,3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Bass Speaker Replacement: 步骤 5 中的图像 1,1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Bass Speaker Replacement, Motherboard: 步骤 6 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Carefully untangle the wires that connect the speaker to the motherboard.
  7. Fugoo Tough XL Bass Speaker Replacement: 步骤 7 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to remove the two ribbon wires on the left and right side of motherboard.
    • Do not pull the cables by the cord, as this could damage the cables and the motherboard. It is best to always disconnect the cables from the base, which is closest to the motherboard, using an iFixit opening tool.
  8. Fugoo Tough XL Bass Speaker Replacement: 步骤 8 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 8 中的图像 2,2
    • There is a hidden ribbon on the motherboard, that becomes visible once the motherboard has been pulled out.
    • Pull the motherboard halfway out.
    • Gently unplug the ribbon using tweezers.
  9. Fugoo Tough XL Bass Speaker Replacement: 步骤 9 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 9 中的图像 2,2
    • Remove the motherboard and battery.
    • Remove the four 3 mm screws from the motherboard using a 3 mm Hex screwdriver.
  10. Fugoo Tough XL Bass Speaker Replacement, Bass Speaker: 步骤 10 中的图像 1,1
    • Remove four 3 mm screws using a 3 mm Hex screwdriver.
  11. Fugoo Tough XL Bass Speaker Replacement: 步骤 11 中的图像 1,2 Fugoo Tough XL Bass Speaker Replacement: 步骤 11 中的图像 2,2
    • Pull the bass speaker from the internal case.
结论
Austin Coats
于02/17/17注册
107 声望
撰写一个指南
团队
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G1
4 名成员
创作了5篇指南
一条评论
Hello, what is the power of this loudspeaker for resistances Ω, and RMS
Marcin Kopera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 764
