跳转到主内容
Fugoo Tough Power Button Replacement
你所需要的
  1. Fugoo Tough Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Fugoo Tough Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Fugoo Tough Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Begin by unscrewing the four 10.72 mm corner screws using the Hex 2.0 screwdriver.
    • Using the Hex 1.5 screwdriver, remove the remaining six 5.79 mm screws on the front of the speaker.
    • Pull the front part of shell away from the back part of shell.
  2. Fugoo Tough Power Button Replacement: 步骤 2 中的图像 1,3 Fugoo Tough Power Button Replacement: 步骤 2 中的图像 2,3 Fugoo Tough Power Button Replacement: 步骤 2 中的图像 3,3
    • Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
    • Pull on the speaker covers to remove them.
    • Rotate the speaker 180 degrees and then remove the four 5.57 mm screws on the side speaker that has the power/bluetooth buttons.
    • Pull apart the side speaker and its casing away from the body of the Fugoo.
  3. Fugoo Tough Power Button Replacement: 步骤 3 中的图像 1,2 Fugoo Tough Power Button Replacement: 步骤 3 中的图像 2,2
    • After pulling apart the side speaker and its casing, you will see both the power and Bluetooth buttons on the underside of the circuit board.
    • Desolder the power button and replace it on the motherboard.
结论
2条评论
Where can I buy the screwdrivers to remove the 4-5.57mm screws?
Frank Peñalo - 回复
Where can you find/source replacement power switches?
ginj - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 469
