跳转到主内容
Fugoo Tough Battery Replacement
你所需要的
  1. Fugoo Tough Battery Replacement, Battery: 步骤 1 中的图像 1,3 Fugoo Tough Battery Replacement, Battery: 步骤 1 中的图像 2,3 Fugoo Tough Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Begin by unscrewing the four 10.72mm corner screws using the Hex 2.0 screwdriver.
    • Using the Hex 1.5 screwdriver, remove the remaining six 5.79mm screws on the front of the speaker.
    • Pull the front part of shell away from the back part of shell.
  2. Fugoo Tough Battery Replacement: 步骤 2 中的图像 1,3 Fugoo Tough Battery Replacement: 步骤 2 中的图像 2,3 Fugoo Tough Battery Replacement: 步骤 2 中的图像 3,3
    • Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
    • Pull on the speaker covers to remove them.
    • Rotate to side the speaker that has the charging port. Remove the four 5.57mm screws facing you.
    • Rotate the speaker 180 degrees and then remove the four 5.57 screws on the side speaker that has the power/bluetooth buttons.
  3. Fugoo Tough Battery Replacement: 步骤 3 中的图像 1,3 Fugoo Tough Battery Replacement: 步骤 3 中的图像 2,3 Fugoo Tough Battery Replacement: 步骤 3 中的图像 3,3
    • Have back of speaker facing you, remove 5-12.70mm screws using 1/16 flat head screwdriver.
    • Using the plastic opening tool, you will be able to wedge back face of speaker off.
  4. Fugoo Tough Battery Replacement: 步骤 4 中的图像 1,3 Fugoo Tough Battery Replacement: 步骤 4 中的图像 2,3 Fugoo Tough Battery Replacement: 步骤 4 中的图像 3,3
    • The circuit board will be revealed, you will notice the various clips/wires that go to the speakers and the battery
    • Remove the blue "clip" from the mother board, then pull the on the speaker and remove it, to give you more room to work
    • Gently pull down on the largest bundle of wires connected to the mother board by a white clip.
    • Battery isn't anchored down, you will be able to pull it out of device
    • The battery can now be replaced
结论
9条评论
Is it waterproof afterwards?
TM M - 回复
what are the battery specs? where can one be purchased?
Miguel Tenorio - 回复
Looks like an 18650 battery with wires soldered to a plastic housing that connects the 2 poles. The battery is slightly thicker but I think it's the wrap around it to keep it as a single unit. Mine just went bad so I'm going to try to swap it out. I'll update if I'm Successful.
Damian - 回复
Update: Success! Worked beautifully. I'll put together some pix I took to wrap it up. If you kinda put it together and test it but the bass is all gone, give it a squeeze. Bass doesn't really show back up til you put screws back in.
Damian - 回复
What battery did you get? 18650? maH?
Tristan Mendoza -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 53
总计 4,285
