跳转到主内容
Fugoo Style XL Speaker Replacement
你所需要的
  1. Fugoo Style XL Speaker Replacement, Fabric Case: 步骤 1 中的图像 1,2 Fugoo Style XL Speaker Replacement, Fabric Case: 步骤 1 中的图像 2,2
    • Using your hand, unscrew the large screws underneath the speaker.
  2. Fugoo Style XL Speaker Replacement: 步骤 2 中的图像 1,3 Fugoo Style XL Speaker Replacement: 步骤 2 中的图像 2,3 Fugoo Style XL Speaker Replacement: 步骤 2 中的图像 3,3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  3. Fugoo Style XL Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Fugoo Style XL Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
  4. Fugoo Style XL Speaker Replacement: 步骤 4 中的图像 1,2 Fugoo Style XL Speaker Replacement: 步骤 4 中的图像 2,2
    • Using your hand, pull the covers away from the speaker.
  5. Fugoo Style XL Speaker Replacement: 步骤 5 中的图像 1,2 Fugoo Style XL Speaker Replacement: 步骤 5 中的图像 2,2
    • Using a #2.0 Hex screwdriver to unscrew the 8 12mm screws depicted.
  6. Fugoo Style XL Speaker Replacement: 步骤 6 中的图像 1,2 Fugoo Style XL Speaker Replacement: 步骤 6 中的图像 2,2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
  7. Fugoo Style XL Speaker Replacement: 步骤 7 中的图像 1,2 Fugoo Style XL Speaker Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
  8. Fugoo Style XL Speaker Replacement: 步骤 8 中的图像 1,3 Fugoo Style XL Speaker Replacement: 步骤 8 中的图像 2,3 Fugoo Style XL Speaker Replacement: 步骤 8 中的图像 3,3
    • Each speaker is attached to the casing with 3mm screws. Remove the screws using a #2.0 Hex screwdriver.
    • Once the screws are removed, carefully lift the speaker from the casing.
结论
另外一个人完成了本指南。
James Gifford
于09/25/17注册
573 声望
创作了5篇指南
团队
USF Tampa, Team S3-G4, Cannon Fall 2017 USF Tampa, Team S3-G4, Cannon Fall 2017 的会员
USFT-CANNON-F17S3G4
4 名成员
创作了5篇指南
一条评论
Hello James,
Nice work. But where can I find the replacement speaker?! Best Regards
Andre Costa - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 774
