跳转到主内容
加入维修社区 - 创建账户
Fugoo Style XL Motherboard Replacement
你所需要的
  1. Fugoo Style XL Motherboard Replacement, Fabric Case: 步骤 1 中的图像 1,2 Fugoo Style XL Motherboard Replacement, Fabric Case: 步骤 1 中的图像 2,2
    • Using your hand, unscrew the large screws underneath the speaker.
    询问修复机器人
  2. Fugoo Style XL Motherboard Replacement: 步骤 2 中的图像 1,3 Fugoo Style XL Motherboard Replacement: 步骤 2 中的图像 2,3 Fugoo Style XL Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  3. Fugoo Style XL Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Fugoo Style XL Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
    询问修复机器人
  4. Fugoo Style XL Motherboard Replacement: 步骤 4 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using your hand, pull the covers away from the speaker.
    询问修复机器人
  5. Fugoo Style XL Motherboard Replacement: 步骤 5 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use a #2.0 Hex screwdriver to unscrew the 8 screws shown in the image.
    询问修复机器人
  6. Fugoo Style XL Motherboard Replacement: 步骤 6 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
    询问修复机器人
  7. Fugoo Style XL Motherboard Replacement: 步骤 7 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
    • When the red bundled cable connectors are disconnected, set the outer casing aside.
    询问修复机器人
  8. Fugoo Style XL Motherboard Replacement: 步骤 8 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 8 中的图像 2,2
    • Untangle any blue bundled cable connectors and gently remove them from the motherboard using a pair of tweezers.
    询问修复机器人
  9. Fugoo Style XL Motherboard Replacement: 步骤 9 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 9 中的图像 2,2
    • Carefully untangle and remove the white bundled cable connectors from the motherboard.
    询问修复机器人
  10. Fugoo Style XL Motherboard Replacement: 步骤 10 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
    • Using your hand, carefully remove the midwoofers.
    询问修复机器人
  11. Fugoo Style XL Motherboard Replacement: 步骤 11 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 11 中的图像 2,2
    • Using a pair of tweezers, lift the padded holding that secures the ZIF connector to the motherboard. The connector will release from the motherboard once the padding is lifted.
    • Do not pull on the cables themselves. Doing so can damage the cables. Always remove the ZIF connector by gently lifting the padding securing them to the motherboard.
    询问修复机器人
  12. Fugoo Style XL Motherboard Replacement: 步骤 12 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 12 中的图像 2,2
    • Carefully lift the battery and motherboard unit halfway out of the casing. The motherboard is connected to the battery directly.
    • There is a small coaxial cable connected underneath the motherboard. Using a pair of tweezers, carefully disconnect and remove the cable from under the adhesive tape.
    • When the cable is disconnected, fully remove the motherboard and battery unit.
    询问修复机器人
  13. Fugoo Style XL Motherboard Replacement: 步骤 13 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the 3mm screws using a #2.0 Hex screwdriver. There are 4 of these screws (2 on each side) that connect the motherboard to the battery unit.
    • When the screws are removed, use an iFixit opening tool to remove the motherboard from the two clamps securing it to the battery pack.
    • Beware! The motherboard is not fully disconnected from the battery even when removed from the clamps.
    询问修复机器人
  14. Fugoo Style XL Motherboard Replacement: 步骤 14 中的图像 1,2 Fugoo Style XL Motherboard Replacement: 步骤 14 中的图像 2,2
    • Using tweezers or your hand, carefully disconnect the bundled cables connecting the battery to the motherboard.
    询问修复机器人
结论
另外一个人完成了本指南。
James Gifford
于09/25/17注册
573 声望
创作了5篇指南
团队
USF Tampa, Team S3-G4, Cannon Fall 2017 USF Tampa, Team S3-G4, Cannon Fall 2017 的会员
USFT-CANNON-F17S3G4
4 名成员
创作了5篇指南
3指南评论
Where can I purchase a replacement mother board?
Vincent walcott - 回复 分享
Are you allowed to tell us where you found a motherboard? I can not find one anywhere for my fugoo
Rhett Mccrady - 回复 分享
A repair guy lost my charging board, is there a way I can bypass it? Or Where can I get a replacement?
David Langat - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 28
总计 1,005
