跳转到主内容
Frozen "Elsa" Singing Doll Battery Replacement
你所需要的
  1. Frozen "Elsa" Singing Doll Battery Replacement, Surgery!: 步骤 1 中的图像 1,1
    • Carefully arrange Elsa's clothing so her body is accessible.
    • Find the Voice Module inside the toy's body.
    • Using a seam ripper, open Elsa up near the Voice Module.
  2. Frozen "Elsa" Singing Doll Battery Replacement, Retrieve the Voice Module: 步骤 2 中的图像 1,1
    • Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • The Voice Module is contained inside a small cloth bag -- open it up with the seam ripper.
  3. Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: 步骤 3 中的图像 1,2 Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: 步骤 3 中的图像 2,2
    • Carefully pry off the top the Voice Module to expose the electronics inside.
  4. Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: 步骤 4 中的图像 1,2 Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the worn LR41 batteries from the Voice Module electronics.
    • Replace with new LR41s, obviously!
    • Warning: button batteries are a choking hazard! Dispose of them properly, and away from children.
结论
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
2等其他人完成本指南。
Dom Santangelo
于09/19/16注册
592 声望
创作了3篇指南
一条评论
my daughter lost an Elsa like this a long time ago, would you mind sharing the name of this product or where you bought it from? Thanks
Marisol Diaz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 5,642
