跳转到主内容
Front License Plate Installation
你所需要的
  1. Front License Plate Installation, Front License Plate Installation: 步骤 1 中的图像 1,3 Front License Plate Installation, Front License Plate Installation: 步骤 1 中的图像 2,3 Front License Plate Installation, Front License Plate Installation: 步骤 1 中的图像 3,3
    • Gather your tools. Drill, Sharpie, Drill Bits, Painters Tape.
    • Get the parts, too. The front license plate bracket and the 4 plastic spreader rivets.
    • Don't forget the Touareg :)
    • Use Painters Tape to mark your drill bits at 1/2" of depth - so you don't drill into the bumper too far.
  2. Front License Plate Installation: 步骤 2 中的图像 1,2 Front License Plate Installation: 步骤 2 中的图像 2,2
    • Position the license plate frame and center it on the VW emblem and parking camera (below, if installed). You can use the vertical supports in the lower grill (hard to see in this pic) to assist in alignment.
    • Hold the license plate frame in place using some painters tape.
    • Using the Sharpie, mark the four holes that you'll be drilling.
  3. Front License Plate Installation: 步骤 3 中的图像 1,1
    • Remove the frame for easier drilling.
    • Using the 1/8" drill bit, drill four pilot holes in the center of each position.
    • Finish the holes by enlarging them with the 11/32" drill bit.
  4. Front License Plate Installation: 步骤 4 中的图像 1,2 Front License Plate Installation: 步骤 4 中的图像 2,2
    • Place the frame back into position.
    • Install the four plastic spreader rivets.
    • Ensure they are seated by using a socket (as shown) to ensure rivets are fully seated before pushing in the center pin.
  5. Front License Plate Installation: 步骤 5 中的图像 1,3 Front License Plate Installation: 步骤 5 中的图像 2,3 Front License Plate Installation: 步骤 5 中的图像 3,3
    • Tap the center pins of the rivets so they are flush with the rivet body.
    • Use #10 x 1/2" Stainless Steel Screws to affix the plate to the mounting bracket. You can see slight indentations where the screws are to go. I drilled pilot holes first.
    • Don't use the "standard" license plate hardware that is 3/4" long. Those screws appear to be long enough to hit the bumper when inserted.
终点
8等其他人完成本指南。
Justin
于10/27/12注册
1,565 声望
创作了3篇指南
6指南评论
I would like to know where the license plate bracket/frame was purchased.
ruthkoljonen - 回复
Nice instructions! I bought my Touareg from Honda dealer with no front plate holder. They ordered me the holder but it came with no instructions. These were perfect! Thank you!!!
TRENT MATTHEWS - 回复
Really, VW. $45,000+ for an ID.4 and *I* have to drill holes in the body to mount the license. This stinks.
E F Charles LaBerge - 回复
Utter bullshit that this is my task
XXX - 回复
This was immensely helpful and the install went seamlessly. THANK YOU JUSTIN!
I had to go buy an 11/32 bit but that was definitely a perfect size for those plastic rivets.
FYI - if anyone is wondering you need to get the part from your VW Dealer, not from some aftermarket/Amazon outfit. Mine was made in Slovakia same as the car and it fit perfectly.
...and yes, my car was from Alberta, Canada and they only use one plate because they are the renegade province of Canada!!
604Pete - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 75
总计 28,339
