简介
Here's an easy step by step tutorial on removing and replacing the inner tube.
First, remove the front wheel from the frame by unscrewing the adjustable screw
Next, wedge tire tool below the bike wheel, right above the rim.
Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
Following this, grab the 2nd tire tool and place it into the gap you have created.
Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
To reassemble your device, follow these instructions.
2等其他人完成本指南。
