跳转到主内容
Frigidaire Gallery Water Filter Replacement
你所需要的
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: 步骤 1 中的图像 1,1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: 步骤 2 中的图像 1,2 Frigidaire Gallery Water Filter Replacement: 步骤 2 中的图像 2,2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: 步骤 3 中的图像 1,3 Frigidaire Gallery Water Filter Replacement: 步骤 3 中的图像 2,3 Frigidaire Gallery Water Filter Replacement: 步骤 3 中的图像 3,3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: 步骤 4 中的图像 1,1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 207
总计 5,037
