跳转到主内容
Frigidaire FFPE45B2QM Refrigerator Door Replacement
你所需要的
  1. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Broken Hinge: 步骤 1 中的图像 1,1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 步骤 2 中的图像 1,1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 步骤 3 中的图像 1,2 Frigidaire FFPE45B2QM Refrigerator Door Replacement: 步骤 3 中的图像 2,2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  4. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Refrigerator Door: 步骤 4 中的图像 1,1
    • Remove the door by slowly lifting straight up, put the door off to the side.
  5. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 步骤 5 中的图像 1,1
    • Get a new, non-damaged door.
结论
2等其他人完成本指南。
Peterluchini
于11/05/15注册
556 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G2
3 名成员
创作了3篇指南
一条评论
So this is a 4.5 cubic foot mini-refrigerator. I suppose the door was damaged in moving the refrigerator - maybe dropped because it has a weight of 58 pounds.
doctordon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 1,411
