跳转到主内容
Frigidaire FFPE45B2QM Broken Hinge Replacement
你所需要的
  1. Frigidaire FFPE45B2QM Broken Hinge Replacement, Broken Hinge: 步骤 1 中的图像 1,1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Broken Hinge Replacement: 步骤 2 中的图像 1,1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Broken Hinge Replacement: 步骤 3 中的图像 1,2 Frigidaire FFPE45B2QM Broken Hinge Replacement: 步骤 3 中的图像 2,2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
结论
Peterluchini
于11/05/15注册
556 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G2
3 名成员
创作了3篇指南
一条评论
That might work on the TOP hinge, but on the bottom hinge the refrigerator would have to be tilted or laid on its side. Also, you could have used a hex socket of the appropriate size instead of the “JIS #1 screw driver“ to remove the bolts.
My refrigerator is a Whirlpool that uses top hinge bolts that require an allen wrench. The bottom is another can of worms, especially with the auto-close.
The previous Whirlpool model had a bottom hinge with a plastic / nylon piece to make it close. When it broke, I made an aluminum piece that kept the door closed.
doctordon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 486
