跳转到主内容
Frigidaire FFHT2022AW Freezer Door Handle Replacement
你所需要的
  1. Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: 步骤 1 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: 步骤 1 中的图像 2,2
    • Remove the screws keeping the handle in place on the bottom face of the freezer door with a Phillips head screwdriver.
  2. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 2 中的图像 1,3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 2 中的图像 2,3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 2 中的图像 3,3
    • Remove any broken pieces of the original freezer handle.
    • Pushing up on any components attached to the handle mount connected to the bottom of the handle should remove anything still connected to the freezer.
    • Use caution when handling broken components.
  3. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 3 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 3 中的图像 2,2
    • Tighten the handle mount at the top of the freezer in place if it is at all loose.
    • A bent mount may not allow the replacement handle to fully attach to the door. Replace this mount if it is missing or damaged.
  4. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 4 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 4 中的图像 2,2
    • If the securing mounts at the top or bottom of the freezer handle are damaged, they will need to be removed.
    • Unscrew the old mount by twisting counterclockwise with a Phillips head screwdriver.
    • This model has replacement screws available for purchase.
  5. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 5 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 5 中的图像 2,2
    • Screw in a new mount by twisting clockwise with a Phillips head screwdriver.
    • The handle mount needs space to properly attach to the handle. Leave some space between the flat part of the mount and the face of the freezer door.
  6. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 6 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 6 中的图像 2,2
    • Secure a replacement handle in place by locking the mount in the top of the handle.
    • The mount should slide into a plastic guide on the top of the handle on the side that faces the freezer door.
  7. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 7 中的图像 1,2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 7 中的图像 2,2
    • Align the two screw holes at the bottom of the replacement handle with the screw holes of the freezer door.
  8. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 8 中的图像 1,3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 8 中的图像 2,3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 步骤 8 中的图像 3,3
    • Secure the handle in place with two screws using a Phillips head screwdriver.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 31
