跳转到主内容
Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement
你所需要的
  1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: 步骤 1 中的图像 1,2 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: 步骤 1 中的图像 2,2
    • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
    • Remove the wheel from the small steel frame.
  2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: 步骤 2 中的图像 1,3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: 步骤 2 中的图像 2,3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: 步骤 2 中的图像 3,3
    • Hold the bolt that connects the wheel to the fork with pliers.
    • This keeps the bolt through the wheel from rotating.
    • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
  3. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: 步骤 3 中的图像 1,3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: 步骤 3 中的图像 2,3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: 步骤 3 中的图像 3,3
    • Flip wheel over and remove the bolt.
    • Remove the castor wheel.
  4. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Obstructing Debris: 步骤 4 中的图像 1,1
    • Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
结论
另外一个人完成了本指南。
Alyssa Chaney
于04/22/13注册
49 声望
撰写一个指南
团队
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G7
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 21
总计 1,446
