当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
With the other hand use the 19mm crescent wrench to hold the nut in place
While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
Remove the wheel from the axle
Unscrew the nut holding the bolt and wheel together using your hands.
It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
Repeat step on other wheel
Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
Repeat above step on second bolt
Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
The axle should come off easily
Slide the baseplates off of the axle
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
