跳转到主内容
Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement
你所需要的
  1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 步骤 1 中的图像 1,2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 步骤 1 中的图像 2,2
    • Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
    • With the other hand use the 19mm crescent wrench to hold the nut in place
    • While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
    • Remove the wheel from the axle
  2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 2 中的图像 1,2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 2 中的图像 2,2
    • Unscrew the nut holding the bolt and wheel together using your hands.
    • It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
    • Repeat step on other wheel
    • Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
  3. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 3 中的图像 1,2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 3 中的图像 2,2
    • Locate the two baseplates on the back of the wheelchair holding the axle in place
  4. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 4 中的图像 1,3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 4 中的图像 2,3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 4 中的图像 3,3
    • Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
    • Repeat above step on second bolt
    • Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
  5. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 5 中的图像 1,3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 5 中的图像 2,3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 步骤 5 中的图像 3,3
    • Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
    • The axle should come off easily
    • Slide the baseplates off of the axle
结论
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
另外一个人完成了本指南。
Mike Sevilla
于04/05/13注册
348 声望
创作了3篇指南
团队
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G7
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 1,519
