当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the chair around and locate the two base plates that hold the axle to the back of the chair.
There are two screws on each of the plates that connect the chair to the axle.
Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
Remove both of the screws from each of the axle plates to free the chair from the axle.
Make sure too keep track of which bolts belong to certain parts of the wheelchair. You do not want to loose track of where each bolt belongs.
Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
There are two screws connecting each of the brakes to the frame.
Remove both of the screws from the frame using the 10mm wrench and pair of pliers.
Locate the screws that hold the back frame, chair, castor wheel, and front frame together.
There is one screw on each side of the chair immediately above where the brakes are located.
Remove both of these screws using the 10mm wrench and a pair of pliers.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
