跳转到主内容
Free Wheelchair Mission GEN 1 Lawn Chair Replacement
你所需要的
  1. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 步骤 1 中的图像 1,2 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 步骤 1 中的图像 2,2
    • Locate the four straps on each corner of the cushion.
    • Untie each of the straps and remove the cushion from the chair.
  2. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 步骤 2 中的图像 1,3 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 步骤 2 中的图像 2,3 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 步骤 2 中的图像 3,3
    • Turn the chair around and locate the two base plates that hold the axle to the back of the chair.
    • There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
  3. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Screws From Axle: 步骤 3 中的图像 1,1
    • Remove both of the screws from each of the axle plates to free the chair from the axle.
    • Make sure too keep track of which bolts belong to certain parts of the wheelchair. You do not want to loose track of where each bolt belongs.
  4. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Brakes: 步骤 4 中的图像 1,1
    • Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
    • There are two screws connecting each of the brakes to the frame.
    • Remove both of the screws from the frame using the 10mm wrench and pair of pliers.
  5. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 步骤 5 中的图像 1,2 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 步骤 5 中的图像 2,2
    • Remove the brakes from the frame.
    • Repeat with the brake on the other side of the wheelchair.
  6. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 步骤 6 中的图像 1,2 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 步骤 6 中的图像 2,2
    • Locate the screws that hold the back frame, chair, castor wheel, and front frame together.
    • There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using the 10mm wrench and a pair of pliers.
  7. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Separate Chair from Front Frame: 步骤 7 中的图像 1,1
    • Remove the front frame and each of the castor wheels from the wheelchair.
  8. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Lawn Chair: 步骤 8 中的图像 1,1
    • Remove the lawn chair from the back frame by lifting it up.
结论
To place a new lawn chair into the wheelchair, follow these instructions in reverse order.
3等其他人完成本指南。
团队
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G7
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,017
