跳转到主内容
加入维修社区 - 创建账户
Framework Desktop Heatsink Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. Framework Desktop Heatsink Installation, Place the heatsink: 步骤 1 中的图像 1,2 Framework Desktop Heatsink Installation, Place the heatsink: 步骤 1 中的图像 2,2
    • Tilt the heatsink down towards the rear of the Desktop and place it into its slot on the Mainboard.
  2. Framework Desktop Heatsink Installation, Tighten the heatsink screws: 步骤 2 中的图像 1,2 Framework Desktop Heatsink Installation, Tighten the heatsink screws: 步骤 2 中的图像 2,2
    • Use your Framework Desktop Screwdriver to tighten the four captive Phillips screws securing the heatsink in an "X" pattern starting with the top right screw.
    • Only tighten the screws a few turns at a time to evenly compress the APU and thermal pads.
    • In order: top right → bottom left → bottom right → top left
    • Use your Framework Desktop Screwdriver to tighten the captive Phillips screw jutting out under the Primary Storage.
结论
Alex Diaz-Kokaisl
于01/16/22注册
218,513 声望
创作了1,087篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 28
