跳转到主内容
Fossil Speedway Watch TI-5061 Watchband Link Replacement
你所需要的
  1. Fossil Speedway Watch TI-5061 Watchband Link Replacement, Band Link: 步骤 1 中的图像 1,1
    • Locate the link on the band with arrows pointing in opposite directions.
    • Place push pin into the hole on one side of the link.
  2. Fossil Speedway Watch TI-5061 Watchband Link Replacement: 步骤 2 中的图像 1,1
    • Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Pull the rod out using your fingers.
    • Repeat on the other side to remove the entire link.
  3. Fossil Speedway Watch TI-5061 Watchband Link Replacement: 步骤 3 中的图像 1,2 Fossil Speedway Watch TI-5061 Watchband Link Replacement: 步骤 3 中的图像 2,2
    • To replace the link, insert the open end of one of the connected links into the open end of the new link.
    • Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
    • Repeat on the other side of the link to remove it completely.
结论
2等其他人完成本指南。
Zachary Price
于04/28/15注册
588 声望
创作了3篇指南
团队
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G10
3 名成员
创作了5篇指南
一条评论
Looking for 3 extra watch band links for a fossil big tic model jr8622 18mm width could you tell me please how much this will cost please with delivery as well to croydon in Surrey
Kind regards colin
Colin Evans - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 1,323
