跳转到主内容
简介
This guide uses Push-pins and a blunt object such as a hammer. There is potential to hurt yourself with the pin or the blunt object. In this case, the blunt object used was the handles of scissors so also be aware of the potential to cut yourself from the scissors.
配件
没有特定配件。
  1. Locate the link on the band with arrows pointing in opposite directions.
    • Locate the link on the band with arrows pointing in opposite directions.
    • Place push pin into the hole on one side of the link.
  2. Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Pull the rod out using your fingers.
    • Repeat on the other side to remove the entire link.
  3. To replace the link, insert the open end of one of the connected links into the open end of the new link. Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
    • To replace the link, insert the open end of one of the connected links into the open end of the new link.
    • Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
结论
Zachary Price
于2015年04月28日注册
549 信誉积分
创作了3篇指南
团队
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G10
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 57
