跳转到主内容
Fossil Q Marshal Gen 2 Screen Replacement
你所需要的
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Screen Replacement: 步骤 2 中的图像 1,1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Screen Replacement: 步骤 3 中的图像 1,2 Fossil Q Marshal Gen 2 Screen Replacement: 步骤 3 中的图像 2,2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Screen Replacement: 步骤 4 中的图像 1,1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Screen Replacement: 步骤 5 中的图像 1,3 Fossil Q Marshal Gen 2 Screen Replacement: 步骤 5 中的图像 2,3 Fossil Q Marshal Gen 2 Screen Replacement: 步骤 5 中的图像 3,3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: 步骤 6 中的图像 1,2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: 步骤 6 中的图像 2,2
    • The screen can now be removed out of the front-side of the watch.
结论
12等其他人完成本指南。
Matthew Tucker
于11/07/17注册
580 声望
创作了3篇指南
团队
IUPUI, Team S2-G5, Harley Fall 2017 IUPUI, Team S2-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S2G5
3 名成员
创作了6篇指南
17条评论
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - 回复
Where can I buy replacement screen for gen 1
David Aslamazashvili -
Is the screen glued to the bezel of the watch?
Jose - 回复
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - 回复
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 131
总计 18,026
