跳转到主内容
Fossil Q Marshal Gen 2 Disassembly
你所需要的
  1. Fossil Q Marshal Gen 2 Disassembly, Back Cover: 步骤 1 中的图像 1,1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Disassembly: 步骤 2 中的图像 1,1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Disassembly: 步骤 3 中的图像 1,2 Fossil Q Marshal Gen 2 Disassembly: 步骤 3 中的图像 2,2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Disassembly: 步骤 4 中的图像 1,1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Disassembly: 步骤 5 中的图像 1,3 Fossil Q Marshal Gen 2 Disassembly: 步骤 5 中的图像 2,3 Fossil Q Marshal Gen 2 Disassembly: 步骤 5 中的图像 3,3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
结论
5等其他人完成本指南。
Matthew Tucker
于11/07/17注册
580 声望
创作了3篇指南
团队
IUPUI, Team S2-G5, Harley Fall 2017 IUPUI, Team S2-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S2G5
3 名成员
创作了6篇指南
4条评论
How do you remove the power switch?
Rahim Parpia - 回复
So when i go to reverse the process. It feels like I connect the top screen and top pieces back in and it won't turn on. Any reason why. Sometimes it vibrates them dnt come up.
Justin Huron - 回复
Thanks, i droped my Fossil Q Founder 2.0 (FTW2119) and this guide help me fix it, i recomend put in the name that also works with mine.
Abílio Páscoa - 回复
Which battery do I need for this watch. I need a replacement.
Pamela Asamoah - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 46
总计 12,756
