跳转到主内容
Fossil Q Marshal Gen 2 Battery Replacement
你所需要的
  1. Fossil Q Marshal Gen 2 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Battery Replacement: 步骤 2 中的图像 1,1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Battery Replacement: 步骤 3 中的图像 1,2 Fossil Q Marshal Gen 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Battery Replacement: 步骤 4 中的图像 1,1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Battery Replacement: 步骤 5 中的图像 1,3 Fossil Q Marshal Gen 2 Battery Replacement: 步骤 5 中的图像 2,3 Fossil Q Marshal Gen 2 Battery Replacement: 步骤 5 中的图像 3,3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
  7. Fossil Q Marshal Gen 2 Battery Replacement: 步骤 7 中的图像 1,2 Fossil Q Marshal Gen 2 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
    Ciao! Ho un Fossil Q Founder (DW2e) Gen 2. E’ lo stesso tipo di batteria ricaricabile? E’ possibile conoscere il tipo di batteria e dove acquistarla? Grazie 1000, sto impazzendo:-)
    Riccardo Filippi - 回复
结论
16等其他人完成本指南。
Clay Walker
于11/07/17注册
752 声望
撰写一个指南
团队
IUPUI, Team S2-G5, Harley Fall 2017 IUPUI, Team S2-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S2G5
3 名成员
创作了6篇指南
13条评论
I have read your awesome guide. This is really helpful.
https://powerbank-online.com/reviews/bat...
Ellen Sam - 回复
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
Rafael “Satriabhi” Atheya - 回复
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
dustykeith17 - 回复
Help! I can’t find a replacement battery.
Pedro Pimentel - 回复
Can't find this model number available anywhere in less than 1000 pieces to buy . Kinda disappointed. On my watch the battery swelled and pushed the display out of the casing which made the disassembly easier but now it's just sat in a bag since I cant find a replacement. Ordered one of ebay that showed up when I searched for this and turned out to be a different model with a different connector
casper denis - 回复
Had the exact same issue
nicolas fuchs -
same problem, easy to open, but hard to find the replacement battery.
anyone with a link? looks like an intel battery inside…
fossil don`t care about selling the battery`s they just what you to buy a new watch
theo buiatti - 回复
Anyone find a battery yet?
Badgersinblack suits - 回复
So it’s 2021, but still I can’t find a battery on the market
msul.nma - 回复
GeLar Store on AliExpress.
Antony Hollingworth -
from where can i get the battery plz do you shop to egypt or dubai
amira.hassanamin - 回复
I have a Michael Kors Smartwatch MKT5003 (battery dead), that it is manufactured by FOSSIL, do you know which is the compatible model? which is the battery number and where do I get the replacement battery??
I need help, please...
Pablo Ariel Olivera - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 70
过去 30 天: 308
总计 40,955
