跳转到主内容
Fosera Scandle 200 Power Switch Replacement
你所需要的
  1. Fosera Scandle 200 Power Switch Replacement, Motherboard Removal: 步骤 1 中的图像 1,1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Power Switch Replacement: 步骤 5 中的图像 1,1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Power Switch Replacement, Power Switch: 步骤 6 中的图像 1,1
    • Locate the Power Switch, and examine the area underneath the yellow plastic.
    • If you find something obstructing the movement, and you can remove it, you're done! If not, proceed with the replacement.
  7. Fosera Scandle 200 Power Switch Replacement: 步骤 7 中的图像 1,1
    • Locate the three prong connectors for the switch on the back of the motherboard. The correct prongs will be right under the print which reads, "Scandle0410 REV.07"
  8. Fosera Scandle 200 Power Switch Replacement: 步骤 8 中的图像 1,1
    • The soldering iron WILL be hot! Don't touch the iron's tip or any parts which have recently been in contact with the iron.
    • The solder around all three prong connectors will need to be melted individually. Push the prongs out with the soldering iron as the solder melts.
  9. Fosera Scandle 200 Power Switch Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of the spudger to pry the power switch from the motherboard. If the switch is still secured, use the pointed end of the spudger to poke the prongs out from the back.
结论
2等其他人完成本指南。
Jared
于09/23/14注册
199 声望
撰写一个指南
团队
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 221
