跳转到主内容
Fosera Scandle 200 Motherboard Removal
你所需要的
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: 步骤 1 中的图像 1,1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: 步骤 2 中的图像 1,1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: 步骤 3 中的图像 1,1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: 步骤 4 中的图像 1,1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: 步骤 5 中的图像 1,1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
终点
团队
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 270
