跳转到主内容
Forerunner 620 Battery and/or Screen Replacement
你所需要的
  1. Forerunner 620 Battery and/or Screen Replacement, Remove LCD: 步骤 1 中的图像 1,2 Forerunner 620 Battery and/or Screen Replacement, Remove LCD: 步骤 1 中的图像 2,2
    • Carefully remove the display of the watch by thoroughly heating the display and gently prying with the help of a suction cup.
  2. Forerunner 620 Battery and/or Screen Replacement, Remove the main board: 步骤 2 中的图像 1,1
    • Remove the screws which secure the main board in place.
  3. Forerunner 620 Battery and/or Screen Replacement, Replace battery: 步骤 3 中的图像 1,3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: 步骤 3 中的图像 2,3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: 步骤 3 中的图像 3,3
    • If the connector for the battery breaks, you can solder the connections directly to the motherboard.
    • If the connector is still intact, you can simply clip the new one into place.
  4. Forerunner 620 Battery and/or Screen Replacement, Replace the LCD: 步骤 4 中的图像 1,1
    • If the LCD is broken, you can replace it by removing the two flat cables which connect it to the main board.
    • The touch screen cable has a lock with a small white lever which should be lifted gently to remove the cable.
  5. Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 步骤 5 中的图像 1,3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 步骤 5 中的图像 2,3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 步骤 5 中的图像 3,3
    • You can now glue the display back in place using B-7000 adhesive.
结论
另外一个人完成了本指南。
phico
于03/22/21注册
295 声望
创作了2篇指南
10指南评论
Where did you find the replacement battery?
Clarence Chung - 回复
I bought this model on Amazon : "
CELLONIC® Smartwatch Replacement Battery PD3032, 361-00047-0 Compatible with Garmin Approach S1, Forerunner 110, Forerunner 210, Forerunner 610, Forerunner S1 Replacement Battery 200 mAh Battery Fitness Tracker
Philippe Collignon -
Do you have the dimensions of the original battery?
Clarence Chung - 回复
Is B7000 adhesive necessary?... or will E6000 also work the same?
Thanks in advance.
jjc - 回复
Changed the battery, all good, except that the touch screen is no longer responding to my touch. :<
Clarence Chung - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 42
总计 3,717
