跳转到主内容
Ford Focus Door Interior dome light assembly Replacement
你所需要的
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: 步骤 1 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: 步骤 1 中的图像 2,2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: 步骤 2 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: 步骤 3 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement: 步骤 3 中的图像 2,2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: 步骤 4 中的图像 1,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 4 中的图像 2,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 4 中的图像 3,3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: 步骤 5 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: 步骤 6 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement: 步骤 6 中的图像 2,2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: 步骤 7 中的图像 1,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 7 中的图像 2,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 7 中的图像 3,3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: 步骤 8 中的图像 1,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 8 中的图像 2,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: 步骤 9 中的图像 1,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 9 中的图像 2,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 9 中的图像 3,3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: 步骤 10 中的图像 1,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 10 中的图像 2,3 Ford Focus Door Interior dome light assembly Replacement: 步骤 10 中的图像 3,3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: 步骤 11 中的图像 1,2 Ford Focus Door Interior dome light assembly Replacement: 步骤 11 中的图像 2,2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
结论
5等其他人完成本指南。
Cassidy
于03/21/16注册
241 声望
撰写一个指南
团队
Michigan Tech, Team 1-11, Lauer Spring 2016 Michigan Tech, Team 1-11, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G11
1 名成员
创作了2篇指南
一条评论
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 46
总计 23,214
