跳转到主内容
Force Reboot PowerBook 180
  1. Force Reboot PowerBook 180, Force Reboot PowerBook 180: 步骤 1 中的图像 1,1
    • To fully restart the power management unit be sure to remove the AC adapter and the battery first and let the PowerBook sit without power for several minutes.
    • Go to back of computer.
  2. Force Reboot PowerBook 180: 步骤 2 中的图像 1,1
    • Have a pen or small enough object and push it into small hole closest to power button
    • You should hear the startup chime
  3. Force Reboot PowerBook 180: 步骤 3 中的图像 1,1
    • If the computer still exhibits the same issue, repeat steps 1 and 2 and then follow the step listed below before reinstalling the battery.
    • Using two paper clips, simultaneously press and hold down the reset and interrupt buttons for 5 to 10 seconds.
结论
David Kehley
于04/11/13注册
101 声望
撰写一个指南
1指南评论
I have an old 180 and it turns on but all I get on screen is the icon with question mark. Each time I try to put in a floppy disk it ejects it every time. I’ve tried rebooting, unplugging so I guess I’m down to a target practice now. LOL
Jim Baskin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,365
