跳转到主内容
FlySky FS-TH9X Joystick Replacement
你所需要的
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: 步骤 1 中的图像 1,1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: 步骤 2 中的图像 1,1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: 步骤 3 中的图像 1,1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: 步骤 4 中的图像 1,1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: 步骤 5 中的图像 1,1
  6. FlySky FS-TH9X Joystick Replacement: 步骤 6 中的图像 1,1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: 步骤 7 中的图像 1,1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 283
