本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will explain how to replace the .440 and 11 Amp fuses. Both fuses can be removed and replaced the same way, so either one can be replaced using this guide. Remember to put the each fuse in its correct socket based on its current rating. To make sure that your replacement fuses are compatible with the Fluke 77 Series III Multimeter, refer to the back panel fuse rating label or the Service Manual.
你所需要的
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Locate the 9V battery in the lower right corner of the device.
Pull the battery out of its terminal.
Locate the fuses near the bottom left corner inside the device.
The .440 Amp fuse is located in the upper left hand fuse holder.
The 11 Amp fuse is located in the lower right hand fuse holder.
Lift the rounded edge of the fuse with one finger until that side is completely out of its holder.
2等其他人完成本指南。
2条评论
Its not that fuse but one like it on the main board in the stereo
Don’t see a fuse on mine. No brand name. New battery. Continuity buzzer not working. And, Voltages Both AC/DC) show . When n ot connected to a voltage. ? Nothing looks out of place. Looks clean inside. Only thing i can think of is trying to get to the switch. That doesn’t look easy. Printed circuit board has to be pryed out. Looks like. WAIT,ther does look like a place for a fuse. But,,nothing there. How didi it work,,at all. Have had it for about 13 years.
