跳转到主内容
Fluke 77 Series III Battery Replacement
你所需要的
  1. Fluke 77 Series III Battery Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Battery Replacement: 步骤 2 中的图像 1,1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Battery Replacement: 步骤 3 中的图像 1,2 Fluke 77 Series III Battery Replacement: 步骤 3 中的图像 2,2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Battery Replacement, Battery: 步骤 4 中的图像 1,2 Fluke 77 Series III Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
  5. Fluke 77 Series III Battery Replacement: 步骤 5 中的图像 1,2 Fluke 77 Series III Battery Replacement: 步骤 5 中的图像 2,2
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
结论
5等其他人完成本指南。
团队
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G10
4 名成员
创作了10篇指南
一条评论
Easy to understand and all went well!
petruskewichw - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 102
总计 19,548
