跳转到主内容
加入维修社区 - 创建账户
Fluance RT83 Belt Replacement
你所需要的
  1. Fluance RT83 Belt Replacement, Belt: 步骤 1 中的图像 1,1
    • Unplug the turntable.
  2. Fluance RT83 Belt Replacement: 步骤 2 中的图像 1,1
    • Lock the tonearm in place with the tonearm clip.
    • If the tonearm is not locked in place, it could move around and potentially damage the needle
  3. Fluance RT83 Belt Replacement: 步骤 3 中的图像 1,1
    • Lift the rubber mat and place it to the side.
    • The rubber mat should come off easily, as it is simply resting on top of the metal platter.
  4. Fluance RT83 Belt Replacement: 步骤 4 中的图像 1,1
    • Unhook the drive belt from the motor pulley.
    • The drive belt is carefully wrapped around the motor pulley, so it is important to unhook it gently.
  5. Fluance RT83 Belt Replacement: 步骤 5 中的图像 1,1
    • Remove the drive belt from the metal platter.
  6. Fluance RT83 Belt Replacement: 步骤 6 中的图像 1,1
    • Grab the new drive belt.
    • Wrap the new drive belt around the motor pulley.
    • Note: When reassembling the turntable, don't forget to wrap the new drive belt around the motor pulley.
  7. Fluance RT83 Belt Replacement: 步骤 7 中的图像 1,1
    • Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
    • If you are having difficulty wrapping the new drive belt around the metal platter, go very slowly and gently. Patience may be required for this step.
  8. Fluance RT83 Belt Replacement: 步骤 8 中的图像 1,1
    • Make sure your drive belt is flush against the platter.
    • It is very important there are no twists in your drive belt.
  9. Fluance RT83 Belt Replacement: 步骤 9 中的图像 1,1
    • Give your metal platter a gentle spin clockwise.
    • When spinning, the platter should continue to spin for a few seconds on its own.
    • If your metal platter is able to spin with the new drive belt attached, you have successfully installed your drive belt.
  10. Fluance RT83 Belt Replacement: 步骤 10 中的图像 1,1
    • Place the rubber mat back on top of the metal tray platter.
结论
Test by playing a record.
Austin Daniel
于09/20/23注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 62
总计 997
