跳转到主内容
加入维修社区 - 创建账户
Flipper Zero Button Replacement
你所需要的
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Button Replacement, Remove the microSD card: 步骤 2 中的图像 1,1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Button Replacement, Remove the screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Button Replacement, Open the back cover: 步骤 4 中的图像 1,3 Flipper Zero Button Replacement, Open the back cover: 步骤 4 中的图像 2,3 Flipper Zero Button Replacement, Open the back cover: 步骤 4 中的图像 3,3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Button Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 1,2 Flipper Zero Button Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Button Replacement, Disconnect the battery: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Button Replacement, Disconnect the ribbon cable: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Button Replacement, Release the battery chassis: 步骤 8 中的图像 1,2 Flipper Zero Button Replacement, Release the battery chassis: 步骤 8 中的图像 2,2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Button Replacement, Remove the ribbon cable: 步骤 9 中的图像 1,2 Flipper Zero Button Replacement, Remove the ribbon cable: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
  9. Flipper Zero Button Replacement, Unscrew the the button chassis: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  10. Flipper Zero Button Replacement, Seperate the button chassis: 步骤 11 中的图像 1,3 Flipper Zero Button Replacement, Seperate the button chassis: 步骤 11 中的图像 2,3 Flipper Zero Button Replacement, Seperate the button chassis: 步骤 11 中的图像 3,3
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
  11. Flipper Zero Button Replacement, The button layout: 步骤 12 中的图像 1,1
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad).
  12. Flipper Zero Button Replacement, Unlatching the buttons: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 1.5 mm Screwdriver
    $5.49
  13. Flipper Zero Button Replacement, Remove the light diffuser: 步骤 14 中的图像 1,3 Flipper Zero Button Replacement, Remove the light diffuser: 步骤 14 中的图像 2,3 Flipper Zero Button Replacement, Remove the light diffuser: 步骤 14 中的图像 3,3
    • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
结论
另外一个人完成了本指南。
Sebastian
于08/19/18注册
31,720 声望
创作了71篇指南
2指南评论
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - 回复
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 111
总计 3,700
