跳转到主内容
加入维修社区 - 创建账户
Flipper Zero Battery Replacement
你所需要的
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Battery Replacement, Remove the microSD card: 步骤 2 中的图像 1,1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Battery Replacement, Remove the screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Battery Replacement, Open the back cover: 步骤 4 中的图像 1,3 Flipper Zero Battery Replacement, Open the back cover: 步骤 4 中的图像 2,3 Flipper Zero Battery Replacement, Open the back cover: 步骤 4 中的图像 3,3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Battery Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 1,2 Flipper Zero Battery Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Battery Replacement, Disconnect the battery: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Battery Replacement, Disconnect the ribbon cable: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Battery Replacement, Release the battery chassis: 步骤 8 中的图像 1,2 Flipper Zero Battery Replacement, Release the battery chassis: 步骤 8 中的图像 2,2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Battery Replacement, Remove the lace mount: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  9. Flipper Zero Battery Replacement, Remove the battery: 步骤 10 中的图像 1,3 Flipper Zero Battery Replacement, Remove the battery: 步骤 10 中的图像 2,3 Flipper Zero Battery Replacement, Remove the battery: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
结论
To reassemble your device, follow these instructions in reverse order and apply new adhesive where needed.
4等其他人完成本指南。
Sebastian
于08/19/18注册
31,811 声望
创作了71篇指南
3指南评论
where can I buy the replacement batterie ?
Piot Gabriel - 回复
where can I get the replacement battery?
collin - 回复
Gokillan Libertux - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 62
过去 30 天: 380
总计 11,915
