跳转到主内容
Flip Video Ultra Power button Replacement
你所需要的
  1. Flip Video Ultra Power button Replacement, Power button: 步骤 1 中的图像 1,1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Power button Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Power button Replacement: 步骤 3 中的图像 1,1
    • Remove the batteries
  4. Flip Video Ultra Power button Replacement: 步骤 4 中的图像 1,1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Power button Replacement: 步骤 5 中的图像 1,2 Flip Video Ultra Power button Replacement: 步骤 5 中的图像 2,2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Power button Replacement: 步骤 6 中的图像 1,1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Power button Replacement: 步骤 7 中的图像 1,2 Flip Video Ultra Power button Replacement: 步骤 7 中的图像 2,2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Power button Replacement: 步骤 8 中的图像 1,1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Power button Replacement: 步骤 9 中的图像 1,2 Flip Video Ultra Power button Replacement: 步骤 9 中的图像 2,2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Power button Replacement: 步骤 10 中的图像 1,2 Flip Video Ultra Power button Replacement: 步骤 10 中的图像 2,2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Power button Replacement: 步骤 11 中的图像 1,1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Power button Replacement: 步骤 12 中的图像 1,3 Flip Video Ultra Power button Replacement: 步骤 12 中的图像 2,3 Flip Video Ultra Power button Replacement: 步骤 12 中的图像 3,3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Power button Replacement: 步骤 13 中的图像 1,1
    • Unscrew the camera housing unit from the plastic case.
结论
Nathaniel Ruf
于10/18/16注册
514 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 440
