跳转到主内容
Flip Video Ultra Camera lense Replacement
你所需要的
  1. Flip Video Ultra Camera lense Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Camera lense Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Camera lense Replacement: 步骤 3 中的图像 1,1
    • Remove the batteries
  4. Flip Video Ultra Camera lense Replacement: 步骤 4 中的图像 1,1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Camera lense Replacement: 步骤 5 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 5 中的图像 2,2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Camera lense Replacement: 步骤 6 中的图像 1,1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Camera lense Replacement: 步骤 7 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 7 中的图像 2,2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Camera lense Replacement: 步骤 8 中的图像 1,1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Camera lense Replacement: 步骤 9 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 9 中的图像 2,2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Camera lense Replacement: 步骤 10 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 10 中的图像 2,2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Camera lense Replacement: 步骤 11 中的图像 1,1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Camera lense Replacement: 步骤 12 中的图像 1,3 Flip Video Ultra Camera lense Replacement: 步骤 12 中的图像 2,3 Flip Video Ultra Camera lense Replacement: 步骤 12 中的图像 3,3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Camera lense Replacement: 步骤 13 中的图像 1,1
    • Unscrew the camera housing unit from the plastic case.
  14. Flip Video Ultra Camera lense Replacement: 步骤 14 中的图像 1,3 Flip Video Ultra Camera lense Replacement: 步骤 14 中的图像 2,3 Flip Video Ultra Camera lense Replacement: 步骤 14 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • With tweezers, remove the microphone and USB connections.
  15. Flip Video Ultra Camera lense Replacement: 步骤 15 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 15 中的图像 2,2
    • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
  16. Flip Video Ultra Camera lense Replacement: 步骤 16 中的图像 1,2 Flip Video Ultra Camera lense Replacement: 步骤 16 中的图像 2,2
    • Remove the single 2.1 mm screw and separate camera from the circuit board.
  17. Flip Video Ultra Camera lense Replacement, Camera lense: 步骤 17 中的图像 1,1
    • Camera lens is now separated from the circuit board.
结论
Nathaniel Ruf
于10/18/16注册
514 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 229
