跳转到主内容
加入维修社区 - 创建账户
Flip Video LCD Screen
你所需要的
    1. Flip Video LCD Screen, Outer Shell: 步骤 1 中的图像 1,2 Flip Video LCD Screen, Outer Shell: 步骤 1 中的图像 2,2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      询问修复机器人
      添加评论
    2. Flip Video LCD Screen: 步骤 2 中的图像 1,1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      询问修复机器人
      添加评论
    3. Flip Video LCD Screen: 步骤 3 中的图像 1,2 Flip Video LCD Screen: 步骤 3 中的图像 2,2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      询问修复机器人
      添加评论
    4. Flip Video LCD Screen: 步骤 4 中的图像 1,1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      询问修复机器人
      添加评论
    5. Flip Video LCD Screen: 步骤 5 中的图像 1,1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      询问修复机器人
      添加评论
    1. Flip Video LCD Screen, Circuit Board: 步骤 6 中的图像 1,1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Flip Video LCD Screen: 步骤 7 中的图像 1,1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      询问修复机器人
      添加评论
    3. Flip Video LCD Screen: 步骤 8 中的图像 1,1
      • Disconnect the USB port cable from the back side of the circuit board.
      询问修复机器人
      添加评论
    4. Flip Video LCD Screen: 步骤 9 中的图像 1,1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      询问修复机器人
      添加评论
    1. Flip Video LCD Screen, LCD Screen: 步骤 10 中的图像 1,1
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Flip Video LCD Screen: 步骤 11 中的图像 1,1
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      询问修复机器人
      添加评论
    3. Flip Video LCD Screen: 步骤 12 中的图像 1,1
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Elizabeth
于04/15/10注册
100 声望
创作了6篇指南
团队
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G21
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 32
总计 5,748
