跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show you how remove the directional buttons. You can then clean them if they are sticky or replace them if they are broken.
配件
没有特定配件。
  1. Turn off the device and take the batteries out. Remove metal sticker under the LCD screen with a spudger.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Open battery door. This can be done by gently depressing and sliding the battery down downward.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Use the spudger to separate outer shells.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Remove the silicone directional pad insert from the front outer shell.
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
结论
另外一个人完成了本指南。
Elizabeth
于2010年04月15日注册
100 信誉积分
创作了6篇指南
团队
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G21
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,823
