跳转到主内容
Flash and re-install the firmware of TCA Yoke
你所需要的
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Yoke from USB port if you already have it plugged-in
  1. Flash and re-install the firmware of TCA Yoke, Press and hold the XBOX button: 步骤 4 中的图像 1,1
    • Press and hold the Xbox button.
    • Make sure to set your Yoke into PC mode, using the switch at the back, before proceeding to the next step.
  2. Flash and re-install the firmware of TCA Yoke, Connect to USB while holding the Xbox button: 步骤 5 中的图像 1,1
    • Keep holding the Xbox button and connect the Yoke to USB port.
    • Once connected, wait a few seconds and let go of the button.
    • Your TCA Yoke should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
终点
Formica Fusca
于08/01/24注册
2,595 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 33
总计 309
