跳转到主内容
Fixing the Phantom Double Clicking on Logitech MX Anywhere 3
  1. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Tools: 步骤 1 中的图像 1,1
    • Those are tools you need.
    • Knife and screwdriver are for opening up the mouse. You may also need an iron (which will help you to soften the glue at the mouse feet).
    • Dust blower, lubricant and tissue are for fixing the click.
  2. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Open up the mouse: 步骤 2 中的图像 1,2 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Open up the mouse: 步骤 2 中的图像 2,2
    • Please follow the instructions in "How to Open Your Logitech MX Anywhere 3" to open up the mouse. It looks like this when you're done.
    • You can heat up an iron and place it on the mouse feet to soften the glue. Be careful when using the iron.
  3. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Disconnect the cables.: 步骤 3 中的图像 1,1
    • Disconnect the cables at the locations marked in red and orange circles. In any case, handle with care to avoid damage to the cables.
    • Cables in red circles can be easily unlocked by lifting the white pins up. You, however, may need to use some force on the orange one.
  4. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: 步骤 4 中的图像 1,3 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: 步骤 4 中的图像 2,3 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: 步骤 4 中的图像 3,3
    • Those are tools you need for this last step.
    • Use the dust blower to blow the dust away.
    • Then, apply some lubricant to the locations marked in blue circles. Make sure you spray the lubricant into the clicking pieces in both the lower and upper parts of the mouse.
    • Make a few clicks and scroll the wheel to ensure that everything works smoothly.
    • Use the tissue to wipe away excessive lubricant before reassembling the mouse.
结论
2等其他人完成本指南。
garfieldknight
于02/13/19注册
1,121 声望
创作了2篇指南
2指南评论
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
Alexandre Abreu - 回复
Estou com o mesmo problema. Encontrou alguma solução?
Breder Augusto -
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 73
过去 30 天: 280
总计 6,440
