跳转到主内容
Fixing the Error Code 165-6596
你所需要的
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: 步骤 1 中的图像 1,2 Fixing the Error Code 165-6596, Removing the stylus and battery lid: 步骤 1 中的图像 2,2
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: 步骤 2 中的图像 1,1
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: 步骤 3 中的图像 1,1
    • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: 步骤 4 中的图像 1,1
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
结论
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
2等其他人完成本指南。
ChrisLord9
于01/06/23注册
307 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 62
总计 2,919
