跳转到主内容
Fixing a scratchy pot/dial
  1. Fixing a scratchy pot/dial, Fixing the scratching noise: 步骤 1 中的图像 1,1
    • To find what pot is making the noise by turning them to see what ones give a reaction
  2. Fixing a scratchy pot/dial, Cleaning the pot: 步骤 2 中的图像 1,2 Fixing a scratchy pot/dial, Cleaning the pot: 步骤 2 中的图像 2,2
    • Pour or spray some isopropyl alcohol into the pot and turn it to help clean the inside
    • Make sure to use as close to 100% purity isopropyl alcohol as you can for the best results!
    • If this doesn't work after a couple attempts you will most likely need to replace the volume pot.
结论
2等其他人完成本指南。
HelloMacOS
于01/24/22注册
27,169 声望
创作了11篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
32 名成员
创作了1,573篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 83
总计 1,762
